2005 equinox xk06 pkg7
avenger2008
Posted: January 16, 2008 at 4:23 PM / IP Logged
I have a XK06 PKG7 Bypass Module Platform #06.
Vehicle a 2005 Chevy Equinox.
Passlock Sensor Connector 3-way BK:
Pin A  OG/WH_812__12-Volt Reference.
Pin B  OG/BK_1057__Sensor Low Reference.
Pin C  YE_1836__Security System Sensor Signal.
XK06 Pin 1 Brown Wire connected to RS Ground when running.
XK06 Pin 2 Green Wire connected to key Ignition side, yellow wire 1836.
XK06 Pin 3 Blue Wire connected to BCM side, yellow wire 1836.
XK06 Pin 4 Violet/White, Instructions unclear which wire on the Equinox to connect to.
XK06 Pin 5 Violet Wire, Tee'ed to OG/BK wire 1057.
XK06 Pin 6 Pink/White Wire Not used ?
XK06 Pin 7 Pink Wire Not used ?
XK07 Pin 8 Orange Wire to RS Start.
XK06 Pin 9 Red, Instructions unclear which wire on the Equinox to connect to.
XK06 Pin 10 Black to Chassis Ground
http://xpressdownload.com/getdocument.aspx?documentid=420    instructions show different connectors and wires than for the Equinox.
Has anyone connected a XK06 to a 2005 Equinox ?
2005 equinox xk06 pkg7 -- posted image.
tc
chadwa2003
Copper - Posts: 353
Posted: January 16, 2008 at 7:41 PM / IP Logged
Hey you are folowing the wrong diagram and using the wrong firmware. You need to use plxr version 1.0 Here is the install manual that you should be following.
http://www.bypasskit.com/getdocument.aspx?documentid=673
robertsc
Copper - Posts: 337
Posted: January 16, 2008 at 7:44 PM / IP Logged
i've had problems with the non starter wire bypasses from bypasskits
equinoxes and canyons
and found that the fortin passlock sl are more reliable
avenger2008
Posted: January 18, 2008 at 11:55 AM / IP Logged
Hey chadwa2003,
Thanks for slapping me back of the head.     One of those days, thinking one thing, looking at it as something else.
Reflashed the XK06 to PLXR v1.02, and rewired to the correct drawing.
Works as its suppose to,   Thanks for the input.       2005 equinox xk06 pkg7 -- posted image.
tc
