2008 buick lucerne
kaczarcollision
Member - Posts: 10
Posted: January 16, 2008 at 9:24 PM / IP Logged
has anybody had any issues with starter delays and which way to wire the starter and ignition wires in the 08 buick lucerne. i am dumbfounded. i am using a xk06 antitheft and pkugm2x for locks. the starter initializes and does not crank. bypasses programmed successfully and the locks work just no crank. any help would be greatly appreciated.
disturbing the peace since 1984
Platinum - Posts: 12,488
Posted: January 17, 2008 at 12:10 PM / IP Logged
What wire did you use for your voltage reference and your resistor wire ? Also, the PKUGM2X requires that you wrap the transponder wire around at least 3-5 times, but I've found that it need to be more like 6-8 times and I use CAT5 wire instead.
extreme1
Silver - Posts: 1,070
Posted: January 17, 2008 at 1:08 PM / IP Logged
xk06 takes care of ign/immo for the vehicle, okugm2x does the same only with an active transponder instead of data.
I think you've overdone the bypass thing a little.
maybe switch out to an idatalink ads-dlsl-gm3 and make your life easier.
Shaughn Murley
Visions Electronics
Red Deer, Alberta
kaczarcollision
Member - Posts: 10
Posted: January 18, 2008 at 10:13 AM / IP Logged
i used the wiring data from directtechs if that helps. im sure i have the bypass' wired up fine and programmed correctly. i'm just a little unsure of my big gauge starter, ign, etc. connections. ?/
backinblack
Posted: January 18, 2008 at 10:34 AM / IP Logged
Make sure you activate the key sense wire when you remote start.  I have found that if you do not, it will not crank.
