thinking about window module in silverado
uglyb0b
Copper - Posts: 55
Posted: January 16, 2008 at 10:13 PM / IP Logged
hi all-
im thinking about doing a window module in my truck (530t in 06 silverado). im hoping to get some info/thoughts/opinions from others:
after looking at the install notes it looks like quite a bit of wires to stuff thru the boots into the door. will this be tough?
this particular car - will i be able to put all wires into driver door, or will i have to run over to passenger? (i want to gain the auto up/down on driver switches only)
any other thoughts or considerations?
thanks
519civiconair
Copper - Posts: 50
Posted: January 17, 2008 at 3:03 AM / IP Logged
The unit is small enough to put in the door requiring few wires to go trhough the door loom. great little unit!!!
F.B.S.S air ride is the only way to roll
ikethegoalie
Copper - Posts: 79
Posted: January 17, 2008 at 9:11 AM / IP Logged
530t is designed to control 2 doors, so putting it in one door seems kind of foolish to me.
I put a pair of them in an 06 Colorado Crew Cab, had to go through molex plugs, but in the end it all worked out fine
Twelvoltz
Platinum - Posts: 2,384
Posted: January 17, 2008 at 9:55 AM / IP Logged
If all you are looking for is window roll ups you can do it with a bypass module. If you are looking for full control (up and down) the 530T is the way to go.
Here is a link to the bypass that will control the windows via data.... Install Manual
