Components, Whats the best?
jagershack
Member - Posts: 8
Posted: February 26, 2003 at 7:20 PM / IP Logged
whats the best component system for high power amps?
esmith69
Gold - Posts: 1,511
Posted: February 26, 2003 at 8:09 PM / IP Logged
There's so many out there.  Helps to narrow it down to a certain price range if possible.  I like MB Quart, Focal, Kicker, and Infinity, but there are many many more to choose from out there.  Also depends on what kind of system you're gonna integrate it with (head unit, back speakers, subs, amps, etc.)
Wantofok
Copper - Posts: 74
Posted: February 26, 2003 at 8:26 PM / IP Logged
Does headunit really make that much a diff?? Need also more info...there isn't a "best" set of components out their...only what sounds best to you and suits your individual needs. I like Boston, Diamond, Focal, MB Quart and Polk Audio personally.
Platinum - Posts: 12,488
Posted: February 26, 2003 at 8:41 PM / IP Logged
Yes, HU does make a difference but I think only in RTA for SQ. Otherwise it's the options, features & looks that will make you decide one model over another.
jagershack
Member - Posts: 8
Posted: February 27, 2003 at 8:37 AM / IP Logged
i want to run 2 sets of components off a punch 500.2 @ 2 Ohm
Big Purds
Silver - Posts: 574
Posted: February 27, 2003 at 10:48 AM / IP Logged
look at Focal, Diamond, a/d/s/, Rainbow, AVI, Dyn, MB Quart, Morel, or Image Dynamics...all very nice sounding speakers, and most of them are capable of handling great amounts of power...
and Jeff is correct, with most of the higher end hu's, it all boils down to what you like...display, features/options, etc...
jagershack
Member - Posts: 8
Posted: February 27, 2003 at 11:04 AM / IP Logged
what i had in mind is:Plans are to run 2 sets of 572.5cf parallel 2 Ohm stereo off a RF 500.2. Understanding that gains may need to be adjusted. Is this too much amp for this application? Does anyone run anything similar.Installed in 2002 explorer sport trac.
Specs follow:Opinions on these speakers are welcome.Any help would be appreciated.
572.5cf
Type: 5" x 7" 2-Way,
Custom-Fit
Speaker Impedance: 4 ohms
Power Handling: 100W RMS, 300W Peak
Sensitivity (2.83V, 1m): 90dB
Frequency Response: 40Hz – 21kHz
Mounting Depth: 2-3/8" (61mm)
Rockford Fosgate 500.2 (2001)
250 W @ 2 OHMS RMS
jagershack
Member - Posts: 8
Posted: February 27, 2003 at 11:05 AM / IP Logged
BTW speakers are infinity kappa
h0twh3els
Member - Posts: 32
Posted: February 27, 2003 at 10:54 PM / IP Logged
I have a nakamichi head unit and im going with a 3-way focal component set. MB-Quart, a/d/s, diamond audio are also some other options.
dyer
Copper - Posts: 206
Posted: February 28, 2003 at 8:31 PM / IP Logged
I personally have 2 sets of MB Quart components in my truck. I did a lot of shopping and looking and in my opinion they are the best sounding component speakers. Remember though different speakers sound better to different people. I would look around and listen to some if you can. If you don't want look, I'd go with MB Quart..you won't be dissapointed.
Dyer
Page of 3
Tuesday, March 17, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
