what amp to buy? better box?
frizkysquirrel
Member - Posts: 47
Posted: January 20, 2008 at 2:28 PM / IP Logged
i have two JL audio 12w3v3's 4 ohm versions.
They are in a sealed box with 1.5 cu ft per sub.
my question is would a JL 500/1 amp be a good match for these.
This is what i have my eyes set on, but if there was an amplifier which would suit them better i am open to suggestions.
i would also like others opinions on what kind of box i should use.
should i go ported or sealed? what cu ft?
here is a link to the specs of the subwoofers.
http://mobile.jlaudio.com/products_subs.php?series_id=25
Thanks in advance :)
aznboi3644
Gold - Posts: 2,600
Posted: January 21, 2008 at 12:59 AM / IP Logged
the 500/1 is an awesome amp...I used to have one. Loved it. Plenty of power for those.
The most important part of a sub system is the enclosure though.
StealthEs
Copper - Posts: 326
Posted: January 21, 2008 at 12:44 PM / IP Logged
That amp would be perfect for those subs. As far as a sealed or ported, all depends. Sealed will give you a cleaner tighter bass. Ported will be louder but not as accurate, nothing unbareable.
Cris
frizkysquirrel
Member - Posts: 47
Posted: January 21, 2008 at 7:17 PM / IP Logged
i think i may go to a ported box.
i am thinking that i will build the box to the manufacturer's specs.
i am also curious to see how they would perform in a bandpass box as opposed to the ported box?
aznboi3644
Gold - Posts: 2,600
Posted: January 21, 2008 at 7:28 PM / IP Logged
If you have no experience designing bandpass boxes I wouldn't recommend it.
If you want a really well engineered enclosure...contact Pete a.k.a. Hexibase at
www.hexibase.com
frizkysquirrel
Member - Posts: 47
Posted: January 22, 2008 at 1:26 AM / IP Logged
yes i wasnt planning on building a bandpass box, but i may decide to build a ported box.
thanks for the reference.
