panasonic deck problems
tak4
Copper - Posts: 76
Posted: January 31, 2008 at 4:36 PM / IP Logged
hello,
Im new here but I did search and still couldnt find much answers. but if its a repost im sorry.
Ever since I removed my dash to paint it, and put it back my Panasonic deck stopped working. When I took it out to look at it better, two exposed wires touched and sparked. So I taped up the exposed aera and checked my fuses and there all fine. My friend said that, the spark could mean its not grounded. but I traced the wire and its grounded to the frame. The fuse in the deck is fine, all wires are well connected, everything else on my dash is working. I was told to get a voltmeter, I did but I have no idea how to use it. I saw in another thread to hit the "reset" button on the back of the face. But when I look on the back there isnt any. I have a Panasonic CG-HR1003U.
When I turn the ignition all the way (before accually turning the car on) I do hear a ticking noise that sounds like its comming from a large fuse under the hood, I only noticed when my deck stopped working. not sure if it always made that sound.
Any idea what could be worng?
audioman2007
Copper - Posts: 580
Posted: January 31, 2008 at 4:55 PM / IP Logged
Which wires touched?
tak4
Copper - Posts: 76
Posted: January 31, 2008 at 4:58 PM / IP Logged
Im pretty sure, it was the speaker wires. they where both white wires with a black stripe, I think. Ok I looked up how to sort of use my voltmeter. I was wondering what settings do I put it at? my things says VDC, VAC, ADC, BAT, and Ohms.
audioman2007
Copper - Posts: 580
Posted: January 31, 2008 at 5:57 PM / IP Logged
Well your speaker wire colors are green, purple, white, grey with the black striped ones being the negative of those wires. So you cant have touched 2 like color wires together unless it was the postive and negative wire of that speaker. Now it is very possible to cause a spike by touching the positive and negative speaker wires together while the deck is turned on. I have already done that with my amp. It spikes then shuts the amp off for a moment. I doubt it would have blown a fuse though.
Dealing with your voltmeter. The only one I know you dont use is VAC as that is house current volts.
tak4
Copper - Posts: 76
Posted: January 31, 2008 at 6:01 PM / IP Logged
so when it spikes, the deck is still fine right? should i try unplug and plug my stock amp back in? Im willing to try anything. haha
