bmw clutch switch
black-bimmer
Member - Posts: 18
Posted: February 01, 2008 at 11:01 PM / IP Logged
i have a 1999 BMW 323is E36 Coupe NOT the E46 model
i was wondering if anyone knows what kind of clutch switch it has: open or closed?
or where can i find that information?
also how would i hook up a relay to it so that my remote start would work?
thanks
KarTuneMan
Platinum - Posts: 7,056
Posted: February 01, 2008 at 11:49 PM / IP Logged
If you install a remote start designed for a manual trans you'll be fine!
What type of unit do you have?
black-bimmer
Member - Posts: 18
Posted: February 02, 2008 at 12:29 PM / IP Logged
i have a scytek galaxy 5100rs...and it says it works with both automatic and manual transmissions but for it to work with manual transmission i have to put a relay on the clutch switch as well as connect the tach wire and the e-brake wire
chriswallace187
Gold - Posts: 1,661
Posted: February 02, 2008 at 3:02 PM / IP Logged
If you can see the switch on the clutch pedal you'll be golden - usually it's just a little plunger switch mounted on the pedal assembly.
Scytek's wiring info doesn't list any clutch wiring for 3-series around that year, so you'll have to meter the switch to figure out if it's closed or open.
The switch will probably be just 2 wires.  Unplug the 2 wire connector. Set your meter for continuity beep, meter the terminals of the switch with the clutch pedal depressed and with it released.  If it beeps with the pedal DEPRESSED, use the OPEN circuit diagram in your manual.  If it beeps with the pedal RELEASED, use the CLOSED circuit diagram. It really won't matter which wire goes to which pin, or if it's closed, which wire you cut - it'll have the same effect.
C Renner's Auto Electronix
black-bimmer
Member - Posts: 18
Posted: February 02, 2008 at 4:06 PM / IP Logged
ok thanks i'll try that
one more question...is the tach wire only found in the speedometer pin or elsewhere like the OBD pin for a bmw E36?
KarTuneMan
Posted: February 02, 2008 at 6:47 PM / IP Logged
clutch bypass. Send a (POS)+ start signal to the BROWN / black at the clutch switch
The tach is found at the diagnostics plug under the hood on the pass. side. It's in the corner by the firewall... the wire is black.
black-bimmer
Member - Posts: 18
Posted: February 02, 2008 at 8:14 PM / IP Logged
what (POS) + start signal do i send to the clutch switch?
from where?
KarTuneMan
Posted: February 02, 2008 at 9:47 PM / IP Logged
Are there any negative outputs that are used for a second accs. or second start? If so use the extra start output to trigger a relay to send the start signal to the clutch.
black-bimmer
Member - Posts: 18
Posted: February 02, 2008 at 11:59 PM / IP Logged
oh ok
black-bimmer
Member - Posts: 18
Posted: February 12, 2008 at 8:00 PM / IP Logged
i have a question
i think my 99 bmw 323is has a chip in the key,
is there anyway i can bypass that chip so
i can make the remote start work?
or did i wire something wrong that it doesnt start?
...everything lights up in the instrument cluster as it
would if the key would be in the "ON" position but then
nothing happens
and i installed a relay to bypass the clutch
Wednesday, April 22, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
