2001 silverado with 1700g bypass
johnson73801
Member - Posts: 42
Posted: February 09, 2008 at 2:26 PM / IP Logged
hi everybody  i purchased a 1600xp python remote start and a 1700g bypass module to install on my 01 silverado? has anyone used this bypass on one of these yet? if so does the door lock function of the 1700g work? or do i need to just hook to the bcm and use a 451m? thanks for all help
techman93
Silver - Posts: 591
Posted: February 09, 2008 at 3:48 PM / IP Logged
The 1700g should do door locks and oem security along with anti theft
The wire I'm test'n isn't doin' what it's supposed to be doin'... I am so glad I printed that tech sheet, with the wrong info.
Do it right the first time... or I might have to fix it for ya
another-kelly
Silver - Posts: 618
Posted: February 09, 2008 at 11:12 PM / IP Logged
will only do door locks, passlock, oem alarm arm/disarm on the '03 and up silverados. the '02 and prior it will only do passlock bypass (and maybe factory alarm disarm. can't remember of the top of my head) but no locks
another-kelly
Silver - Posts: 618
Posted: February 09, 2008 at 11:19 PM / IP Logged
also, you don't need the 451m for the locks at the bcm. just connect the blue and green to your unlock and lock
johnson73801
Member - Posts: 42
Posted: February 11, 2008 at 3:23 PM / IP Logged
alright i looked a  diagram and it shows + pulses to the relays from the switch. doesnt the alarm module send one signal for lock and reverse the signal for unlock?
another-kelly
Silver - Posts: 618
Posted: February 11, 2008 at 4:57 PM / IP Logged
don't mind the - pulse, won't matter for ya.
Power Lock       +      lt. blue          brown plug @ BCM
Power Unlock     +      white           brown plug @ BCM
connect the python's green (+) unlock to the white wire at the BCM and the python's blue (+) lock to the lt. blue at the BCM
