metrik car alarm, siren
tak3pchd
Posted: February 10, 2008 at 10:49 PM / IP Logged
I have hooked up a {[metrik 272] by metrikmobile}on my car. Everything works fine,(parking lights flash, shock sensor etc.),
but the siren makes a weak warbled sound when it is hooked up.
if i unhook the siren the system works fine as far as activating and flashing the lights for arm/disarm and triggering.
I have checked and doublechecked the wiring according to the manual.
thanx tak3pchd
chadwa2003
Copper - Posts: 353
Posted: February 11, 2008 at 9:51 AM / IP Logged
Check your grounds for the main unit and the siren
tak3pchd
Posted: February 12, 2008 at 8:38 AM / IP Logged
all grounds are good cause they are at the battery negative terminal.
could this be a problem? i mean if all the grounds are too close to each other. i am starting to think the "brain" of the alarm is defective. if so what can i do? the manufacturer does not have much support online. i got this alarm for $35. new. i was looking for a simple alarm. any suggestions.
thanx tak3pchd
chadwa2003
Copper - Posts: 353
Posted: February 12, 2008 at 3:32 PM / IP Logged
What is the condition of the battery terminals are the clean and free of corrosion
