destroying enclosure
killa101
Copper - Posts: 53
Posted: February 14, 2008 at 6:00 PM / IP Logged
Have any of you guys ever have an enclosure break just from the sub(s)? I'm talking about a box made out of 3/4" MDF.
DYohn
Moderator - Posts: 10,741
Posted: February 14, 2008 at 6:27 PM / IP Logged
SPL comp cars, maybe.
audiocableguy
Copper - Posts: 630
Posted: February 14, 2008 at 6:37 PM / IP Logged
I have seen 3/4" MDF crack around screw holes and baffle area around the driver. Have never seen a box break from the shear force of the driver. Bad design, poor construction or lack of proper support would most likely be the cause.
sedate
Silver - Posts: 1,173
Posted: February 14, 2008 at 8:17 PM / IP Logged
I missed a critical joint in a box I built for a JL 13w6 with a deck screw - the shelf in question was only held in with dried fiberglass and a bit of Liquid Nail - the deck screw sort of screwed through the first piece of MDF and just missed the second at this sort of awkward, splintered out angle.  I missed the mistake when I was fiberglassing the box.
So for a day - it was the best sounding box I had ever built for the sub.
Two days after I built the box the thing exploded during a rendition of Eazy-E's Real G's- and took my 13w6's voice coils' with it.destroying enclosure -- posted image.
audiocableguy
Copper - Posts: 630
Posted: February 14, 2008 at 9:14 PM / IP Logged
Sounds like an expensive afternoon! Your box or customers?
A few ideas:
15" or larger drivers get 1" baffle. Any panel larger than 12" square gets braced. Titebond glue, fine thread drywall (1.5" for countersunk and 1.75" non-counter) and T-nuts for driver mounting. Predrill all holes and hand tighten screws. Silicon joints. Bracing is same material as box.
audiocableguy
Copper - Posts: 630
Posted: February 14, 2008 at 9:29 PM / IP Logged
Sorry Sedate, I was just thinking out loud about box builing and didn't mean to imply you need any tips! "A few ideas" part was just throwing it out there! Fiberglass is a whole other ballgame.
sedate
Posted: February 14, 2008 at 10:06 PM / IP Logged
Naww - I mean - it was a *real* noob mistake - and as you observe, easily among the most expensive I've ever made. destroying enclosure -- posted image.
aznboi3644
Gold - Posts: 2,600
Posted: February 14, 2008 at 11:17 PM / IP Logged
I've had an enclosure I built for a friend with two Type R's come apart at one seam.
It was only because the glue we used was heavy duty liquid nails. I told my friend liquid nails is a horrible adhesive for wood and that normal wood glue is a lot stronger. But he refused my suggestion. After we finished the box and after all the liquid crap had dried I backed out all of the screws.
Then a week later the back bottom seam broke open. I could pull apart the panels with my hands. The liquid nails just failed and didn't even take any MDF with it. All liquid nails does is just "stick" the wood together. I use Titebond Original and Titebind II. Both have never failed on me even after backing out all screws
Steven Kephart
Platinum - Posts: 1,737
Platinum spaceThis member has been recognized as an authority in Mobile Audio and Video. Click here for more info.spaceThis member consistently provides reliable informationspace
Posted: February 15, 2008 at 1:42 AM / IP Logged
We had an Obcon pre-fab enclosure designed for the Ford F150  with dual Planet Audio 10's blow apart on a customer.  It was the only time I've ever seen that happen.
haemphyst
Platinum - Posts: 5,059
Posted: February 15, 2008 at 10:15 AM / IP Logged
Gorilla Glue. NEVER have I seen a single seam blow apart, and I don't even use screws to hold it during cure time. Clamps, and you're done. Of course, this construction method mandates perfect cuts, so proper measurements and careful setup and use of your TABLE SAW (i.e. NOT a Skil-Saw... FAR too inaccurate) are of utmost importance.
I have actually had to DESTROY enclosures I have built this way to remove them from the vehicle in which they were installed, and the MDF gave way LONG before the joint did. Every home enclosure I have ever built is nothing but Gorilla Glue. I hate filling and sanding screw holes.
Gorilla Glue. 'Nuff said...
:::::EDIT:::::
Now what I think about it, I remember a STONE enclosure I built for a woofer... Yes, STONE! I bought floor covering, cut the pieces to the required sizes, (I used my table saw with a dry abrasive blade) laminated pieces of it for the sides, and I built an enclosure of stone for a 10" woofer once. (I want to say it was a Titanic 10 - the first version, and the thing weighed, like, 75 pounds when I was done! WHATEVER it weighed, it was pretty damn heavy for a 12 inch cube!) As far as I know, it's still running to this day, and THAT was all Gorilla Glue, as well. Yes, that stuff is THAT bad-azz!
Page of 3
Saturday, July 12, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
