2002 Ram 1500 Trk Diagram?
GTIinc
Member - Posts: 7
Posted: May 29, 2002 at 8:26 PM / IP Logged
Does anyone have the diagram to the 2002 Ram Trucks?.  Specially the 1500 series?
"Oh yeah, And What Is It With All These Quotes"
Moderator - Posts: 12,488
Posted: May 29, 2002 at 8:49 PM / IP Logged
Dodge
Ram Pickup
2002
Remote Starter  Wiring Colors and Notes
Function
Vehicle  Color
Location
Start:
YELLOW
IGNITION SWITCH HARNESS
Ignition  #1:
BLUE (16 AWG)
Ignition #2:
RED
Ignition  #3:
GREEN & ORANGE (2 WIRES)
Accessory:
BLACK/ WHITE & BLUE (2 WIRES)
Brake  Light:
WHITE/ TAN
AT SWITCH ABOVE BRAKE PEDAL
Tach  Signal:
TAN/RED
AT IGNITION COIL
Parking Lights:
PURPLE / YELLOW
HEADLIGHT SWITCH*
Headlights:
PURPLE / YELLOW
HEADLIGHT SWITCH *
OEM Alarm  Disarm:
LT. GREEN/ ORANGE *****
HARNESS COMING IN FROM DRIVER'S DOOR
OEM Alarm  Arm:
Diesel  Glow Plug:
Clutch  Bypass Wire:
Notes:
 * This Is A Single Wire System. Parking Lights Need To See A Ground (-) Through A 1.4 K-Ohm Resistor. Headlights Need To See A Ground (-) Through A 1.8 K-Ohm Resistor. ** Diesel Vehicles - ORANGE / Black Wait to Start; Tach Wire Is Gray/Black. Both Wires Are Located In A Black Connector Center Top Of Fire Wall. There Are Two Black Connectors, The Correct One Does Not Have A White Insert.
Dodge
Ram Pickup
2002
Alarm and Keyless  Entry Wiring Colors and Notes
Function
Vehicle  Color
Location
Constant  +12 Volts:
PINK/BLACK
Starter  Kill:
YELLOW
Ignition  +12 Volts:
BLUE (16 AWG)
Dome  Lights/Superv:
SEE NOTE ***
OEM Horn:
BLACK/ RED (-)
STEERING COLUMN HARNESS
Power  Lock:
WHITE/ GREEN
DRIVER'S KICK PANEL ****
Power  Unlock:
WHITE/ GREEN
Trunk  Release:
N/A
Alarm  Input Wire:
SEE NOTE ***
Notes:
*** Separate Triggers For Each Door. The Driver's Door Trigger Is Tan (-). The Left Rear Door Trigger Is Tan/Orange (-). Both Wires Can Be Found In The Driver's Kick Panel. The Passenger Front Door Trigger Is Tan/Red (-) And the Passenger Rear Door Trigger Is Tan / YELLOW (-). Both Of These Wires Can Be Found In The Passenger Kick Panel. Diode Isolate Each Wire For Alarm Trigger With The Bands Facing Away From The Alarm/Remote Start Module. Use Only One Trigger For Dome Light Supervision. **** Single Wire Door Lock System. Lock Requires A Ground (-) Pulse Through A 867 Ohm Resistor. Unlock Requires A Ground (-) Pulse Through A 364 Ohm Resistor. Diode Isolate One Of The Wires. ***** Requires A Negative Pulse Through A 1.5 K-Ohm Resistor
GTIinc
Member - Posts: 7
Posted: May 30, 2002 at 10:30 PM / IP Logged
Thanks Jeff.  I knew I could count on you.
"Oh Yeah, And What Is It With All These Quotes"
Lenknermj
Member - Posts: 17
Posted: July 23, 2002 at 10:20 PM / IP Logged
I also am putting a starter in a 2002 Ram 1500.  I have a question about IGN3 and ACC wires.  They both have 2 wires according to this list.  So, how do I hook up my single output wire from the starter to the wire listed?  Do I simply split the output and splice into both?  I'm thinking this would bridge the wires and be a 'not-so-good' choice.
What are the other (correct) options?
BTW, Jeff (et al) thanks for your assistance...I would have returned this starter to the store by now had it not been for "y'all".... =)
- Mark
dan768
Copper - Posts: 49
Posted: July 23, 2002 at 11:37 PM / IP Logged
Year(s): 2002
Make(s): Dodge
Model(s): Ram 1500
12 Volt (+)
12ga. RED / White or Pink/Black at ignition harness
Ignition 1
14ga. Lt. Blue at same
Ignition 2
14ga. RED / White at same
Ignition 3
Accessory 1
Accessory 2
Starter
14ga. Yellow at same
Horn
16ga. GREEN/ Red (+) at fuse box under hood in Blue connector (remove 13mm bolt and plastic screw holding fuse box, slide out and flip over)
Tachometer
Lights (+)
16ga. BLACK / YELLOW in same harness as horn wire
Lights (-)
18ga. Violet / YELLOW at light switch @ 500-1000 ohm (turns on parking and head lights)
Brake Lights
Door 1
18ga. Tan (-) at white connector above driver’s kick panel (driver door) OR ALL TRIGS CAN BE FOUND TO THE RIGHT OF THE STEERING
Door 2
18ga. 18ga. Violet/Orange (-) at same (rear left door) COLUMN, LOOM RUNNING TO BEHIND GAUGES.TEST FOR
Door 3
18ga. Tan/Red (-) at passenger kick (right front door) VIO/ORG THERE ARE TWO.
Door 4
18ga. Tan / YELLOW (-) at same (right rear door)
Interior Lights
Trunk/Hatch
Hood Pin
Trunk Release
Lock (switch)
18ga. WHITE/ Green (-) @ 830 ohm next to driver’s side door pins (see diagram) OR 560 ohm
Unlock (switch)
Same wire @ 320 ohm OR 2*249 in parallel
Driver Unlock
Arm (key)
18ga. Lt. GREEN/ Orange (-) @ 2k at same
Disarm (key)
Same wire @ 500ohm
Arm Input
16ga. Tan/Pink (M) at same (wires rest open, ground to chassis with 10k ohm resistor, also advise resistor in line to prevent rearming on second unlock)
Disarm Input 1
16ga. Lt. Blue (M) at same (wire also rests open)
Disarm Input 2
16ga. Tan/Orange (M) at same (wire also rests open)
I just wanted to show another tested and proved wiring diagram.
dan
Remember (there are no hard cars,some just take longer to install on then others)
Tuesday, November 11, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
