Sensor
bizzy818
Copper - Posts: 60
Posted: February 28, 2003 at 11:15 PM / IP Logged
One thing I don't understand is why do they put a glass sensor when there is shock sensor? whats the difference in does? if hit the car the alarm turns on of shock sensor, isn't it the same thing as hitting the window? thnx
auex
Platinum - Posts: 5,041
Posted: February 28, 2003 at 11:20 PM / IP Logged
The glass break sensor basically listens for the high freqeuncy that breaking glass makes. Shock sensors are made to pick up impact, since the glass is usually not mounted securely to the body of the car the shock sensor will not always pick up a window being broke out, usually if it does then it also falses alot. In my opinion I would prefer a glass break sensor over a shock sensor.
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
Two_Cold
Copper - Posts: 91
Posted: March 01, 2003 at 4:18 PM / IP Logged
Shock sensors tend to have a higher rate of false alarms. If a large truck passes the parked car it can set it off. I disconnected mine because of that reason. I only use a glass sensor and a motion sensor. Although the motion sensor has it's share of false alarms too.
Friday, April 24, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
