Autopage RF-1055KE -- Audi A4 install
a4_sea_pdx
Posted: March 02, 2003 at 1:33 AM / IP Logged
I'm planning to install the Autopage RF-1055KE into my 1996 Audi A4 and I'm running into some difficulty determining how to wire it.
Under the rear seat cushion is the wiring harness for the OEM receiver that I'm planning to replace with the Autopage Unit. Can anyone assist with wiring info?
I appreciate any help you can provide!
Thanks!
rh Autopage RF-1055KE -- Audi A4 install -- posted image.
Moderator - Posts: 12,488
Posted: March 02, 2003 at 6:55 AM / IP Logged
|              12V|red                 |+  |ignition harness            |
|          STARTER|RED / black           |+  |ignition harness            |
|   SECOND STARTER|blue                |+  |ignition harness            |
|         IGNITION|black               |+  |ignition harness            |
|        ACCESSORY|BLACK / YELLOW        |+  |ignition harness            |
|       POWER LOCK|RED / brown           |-  |drivers kick or alarm *1    |
|     POWER UNLOCK|gray/white *4       |-  |drivers kick or alarm *1    |
| PARKING LIGHTS +|gry/blk & gry/red   |   |headlight switch            |
|       HEADLIGHTS|yellow              |+  |headlight switch            |
|     DOOR TRIGGER|BROWN / white         |-  |any passenger switch        |
| DOME SUPERVISION|use door trigger    |   |                            |
|  TRUNK/HATCH PIN|BROWN / blue          |-  |at trunk light              |
|         HOOD PIN|BROWN / red           |-  |at hood pin switch          |
|  FCTRY ALARM ARM|arms with lock      |   |                            |
|FCTRY ALRM DISARM|disarms with unlock |   |                            |
|       TACHOMETER|GREEN/ blue          |   |instrument cluster or *2    |
|      SPEED SENSE|WHITE/ blue          |   |instrument cluster or *3    |
|       BRAKE WIRE|RED / black           |+  |at switch                   |
|     HORN TRIGGER|BLACK / YELLOW        |+  |horn relay                  |
|           WIPERS|blk/gry(L),grn/yel(H|+  |steering column             |
Notes:
*1 Factory alarm is on the bottom passenger side of the trunk or under rear seat.   *2 Tach is also found at the ECM on the driver side firewall.  *3 VSS is also found at the cruise control module behind the glove box.  *4 Unlock requires double pulse.
You don't have to remove the OEM system ( this will cause troubles for you if you do remove the OEM system ). Just piggy back the OEM system where you have to.
a4_sea_pdx
Posted: March 02, 2003 at 12:10 PM / IP Logged
Thanks! I'll update the thread when it's installed :)
a4_sea_pdx
Posted: March 04, 2003 at 2:57 AM / IP Logged
I took the advice to leave the OEM item in and connected the Autopage RF-1055KE system. Everything worked well except the unlock command. I programmed it to short & long pulses and to double pulse ... all to no avail. I think the vacuum lock system might be causing the problems. Does anyone have any suggestions? Direct experience with this unit?
Sunday, November 9, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
