529t controlled duration with 562t
tjetzer
Member - Posts: 6
Posted: March 13, 2008 at 11:47 AM / IP Logged
Is it possible to do controlled duration in both directions (One motor, up and down) with a 562T remote start?  If so, which wires off the 562T would be used?
Posted: March 13, 2008 at 1:11 PM / IP Logged
Just looked on directechs couldn't find a 562t what brand is it ? Viper Hornet etc? The leads  you want on the 529t are the grey and grey /black
Posted: March 13, 2008 at 1:18 PM / IP Logged
Have you got a violet/black and WHITE/ black channel 4 & 5 outputs? You can use these to send window up and down. Look at 529t instructions, cut up feed and down feed to motor and follow the colours accordingly.
tjetzer
Member - Posts: 6
Posted: March 13, 2008 at 2:26 PM / IP Logged
Howie,
Thanks for the reply.  It's a Valet 562T.  It does not have a 5th output, only a 4th.
Here is the real issue I'm having.  The 529T is not going to be controlling a window, it will be controlling the power trim on a boat.  The only real change in resistance/current draw would be when the tim hits a certain point and changes from a fast ascent/descent to a slow ascent/descent.  I would prefer the controlled duration so the trim can be controlled at all times rather than have full up/down.
Do you have any suggestions?
Posted: March 13, 2008 at 2:58 PM / IP Logged
orry I jumped in before, ignore the grey and grey/black, use orange and and orange back, are you using the the red white on the 562t?
tjetzer
Member - Posts: 6
Posted: March 13, 2008 at 4:22 PM / IP Logged
I haven't installed anything yet.  The red black wire will not be used for anything.  I assume that wire is controlled by the "AUX" on the remote, then I could use the Channel 4 wire for the other validity channel.  This would then give me controlled duration, correct?
