99 jeep cherokee running 0ga cable
01sesedan
Member - Posts: 40
Posted: March 25, 2008 at 11:57 AM / IP Logged
I have a 99 Jeep XJ Cherokee and wanted to know if any of you guys have run 0ga in it before. On my previous vehicle (Suburban) I ran the cable to the rear under the body along the chassis and back up again.
In the jeep, I don't see were I could run the cable through the interior but maybe you guys have some ideas.
Hope you could give me some tips..
Thanks...
stevdart
Platinum - Posts: 5,816
Posted: March 25, 2008 at 9:08 PM / IP Logged
Here's my tip:  never run a power wire under the vehicle.  Find a way to run it inside.
01sesedan
Member - Posts: 40
Posted: March 25, 2008 at 11:21 PM / IP Logged
Thanks, will take apart the interior and see if there is space on either side. Will let you guys know..
klctexas
Copper - Posts: 111
Posted: March 26, 2008 at 2:31 PM / IP Logged
Yeah, that sounds like a good way to ruin some expensive cable, if something were to bounce up and slice it, then you have a risk of starting a fire or something unless you were to pull over and unhook the cable from the battery... which would be a pain in the neck. (Not as bad as replacing that cable probably though)
Soldier: This is the worst part. The calm before the battle.
Fry: And then the battle is not so bad?
Soldier: Oh, right. I forgot about the battle.
force
Member - Posts: 24
Posted: March 28, 2008 at 10:01 AM / IP Logged
Any luck on running the 0 ga?
01sesedan
Member - Posts: 40
Posted: April 01, 2008 at 9:10 PM / IP Logged
No luck yet, for the past couple of weekends...every time I get everything together, it starts to rain. Will let you know when I get it done.
Was thinking for running flexible conduit underneath but still scoping it out..
Wednesday, November 29, 2023 • Copyright © 1999-2023 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
