new head unit matched with old equalizer
waveshredder
Member - Posts: 15
Posted: March 27, 2008 at 9:37 AM / IP Logged
Hello all! I have an old Alpine 3311 equalizer that is in mint condition and i want to use it with my stereo installation. Unfortuneately, the head unit is an Alpine 7163 and is a cassette deck. I don't even own any cassettes anymore. I am going to buy a new deck. Question is, can I hook up the old EQ with any of the newer decks? Has anybody done this with this particular EQ and what deck did you hook it up with? Any help with this would be greatly appreciated.
"To defy the laws of tradition, is a crusade only of the brave" Primus
Platinum - Posts: 13,716
Posted: March 28, 2008 at 5:11 AM / IP Logged
You will have no problems using that EQ with a new deck.
waveshredder
Member - Posts: 15
Posted: March 28, 2008 at 6:44 AM / IP Logged
Thanaks for the reply !   How do I hook it up?  Thanks again !!
Posted: March 28, 2008 at 7:11 AM / IP Logged
I never really pay attention to the model numbers.  I thought that this was a standard EQ with a yellow constant 12 volt wire.  A black ground wire, and a blue remote turn on wire.  And RCA jacks for input, front, rear and subwoofer outputs.  But since you are asking how to hook it up.  This must not be the case.  Does it have 8 pin din plugs for input and output?
waveshredder
Member - Posts: 15
Posted: March 28, 2008 at 8:13 AM / IP Logged
Yes it does. The outputs are fine.
haemphyst
Platinum - Posts: 5,059
Posted: March 28, 2008 at 8:32 AM / IP Logged
Then you need an Alpine to RCA adapter. I'm not sure you can actually still get them, but eBay is a good source for old style connectors like that. Otherwise, possibly your local Alpine dealer can come up with something for you. (I don't usually recommend eBay, but in this case it MIGHT be your best option, although not your ONLY option...)
Your smaller shops will be FAR more likely to help you out than the big box stores, try them first. (Not to mention the fact that they will know their asses from a hole in the ground, usually...)
Posted: March 28, 2008 at 3:57 PM / IP Logged
I don't remember asking if the outputs were OK but I guess i must have.  The important question was    Does it have (8 PIN) din plugs for the input and output?  If so I think I have an old amp in my shop somewhere so I can power it up and draw you a diagram for the din plugs.  I remember the pin out for the ones with RCA and remote.  Don't remember where constant and switched is in the plug.
waveshredder
Member - Posts: 15
Posted: March 28, 2008 at 4:54 PM / IP Logged
Thanks again for the help! I can send you a diagram of the plugs for the 3311 that Alpine sent me. my email address is old_surfer_dude@msn.com. I'll reply and send them to you. Thanks.
waveshredder
Member - Posts: 15
Posted: March 29, 2008 at 7:46 AM / IP Logged
I emailed the din plug specs to the email you sent me.  Thanks.
Posted: March 29, 2008 at 3:28 PM / IP Logged
Radio Shack sells the din plugs you need to make this up.  You will need one 5 pin male din and three 8 pin female dins.  If you are using 3 amps.  I know that the input plug is an 8 pin plug, the extra pins are to supply constant and switched power to the older Alpine decks.
Monday, July 14, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
