peugeot 307cc wiring diagram car alarm
ctflight
Posted: May 04, 2008 at 5:43 PM / IP Logged
please who has Peugeot 307 cc year 2005 wiring diagram? please send me by mail ( ctflight13@hotmail.com) or here...
Also please can anyone tell what system locking is (positive , negative or pneumatic lock and wiring please :) )
Thank you all
kola7126
Copper - Posts: 93
Posted: May 07, 2008 at 3:46 PM / IP Logged
08/03/2003 rev.00
<"Arial" >
PEUGEOT 307 2003 29.27
LOCATION OF THE CAR ALARM CONTROL UNIT
<"Arial" >
Compact control units and sirens: <"Arial" >place in the housing for the windscreen wipers on driver’s side.
<"Arial" >
Modular control units and accessories: <"Arial" >place under the dashboard, to the left underneath the BSI control unit.
CAR ALARM SUPPLY
<"Arial" >
Positive: <"Arial" >Connect to the wire <"Arial" >(pos.n°8) <"Arial" >in the Black 16-pin connector on the BSI control unit.
<"Arial" >
Negative: <"Arial" >Connect to the manufacturer’s original setting located to the left of the steering column.
IMMOBILISER
<"Arial" >
The vehicle is fitted with an original transponder engine immobiliser which automatically arms when the vehicle’s key
is removed from the ignition.
<"Arial" >
SPEEDOMETER
<"Arial" >
Connect to the <"Arial" >GREEN/ Brown (pos.n°4) <"Arial" >wire in the Black 9-pin connector on the electric pump for the power steering, located
under the bonnet on the passenger’s side close to the headlamp (accessed from the underside of the vehicle).
POSITIVE IGNITION KEY (+15)
<"Arial" >
Connect to the wire <"Arial" >(pos.n°6) <"Arial" >in the Grey 16-pin connector on the BSI control unit.
CENTRAL DOOR LOCKING (Connection with radio frequency remote controlled alarm)
<"Arial" >
Negative type control.
<"Arial" >
Connect to the <"Arial" >Dark Blue <"Arial" >wire n° <"Arial" >625 (pos.n°6) <"Arial" >for locking in the Black 6-pin connector in the push button in the middle of
the dashboard and connect to the <"Arial" >Grey <"Arial" >wire (position n° 27) for unlocking in the White 40-pin connector on the BSI control
unit under the dashboard on the driver’s side.
ARMING OF PASSIVE TYPE ALARM (Connection with alarm armed by vehicle’s original
remote control)
<"Arial" >
Follow method of connection in <"Arial" >< color=#ff0000>INSTALLATION FILE 29.27.2
<"Arial" >
DIRECTION INDICATORS
<"Arial" >
Connect to the <"Arial" >Brown <"Arial" >wire n°<"Arial" >289 (pos.n°14) <"Arial" >and to the <"Arial" >Red <"Arial" >wire n°<"Arial" >290 (pos.n°13) <"Arial" >in the Black 16-pin connector on the BSI
control unit.
DOORS PROTECTION
<"Arial" >
Connect to the <"Arial" >Grey (pos.n°27 – front LEFT), Dark Blue (pos.n°5 – front RIGHT), Dark Blue (pos.n°34 – rear LEFT),
Purple (pos.n°33 – rear RIGHT) <"Arial" >wires located in the White 40-pin connector on the BSI control unit.
Follow method of connection in <"Arial" >< color=#ff0000>INSTALLATION FILE 29.27.1
<"Arial" >
When the M750/9 alarm is fitted, the boot and door switches are normally read by the VAN line.
<"Arial" >
BONNET/BOOT PROTECTION
<"Arial" >
Bonnet: <"Arial" >Fit the switch provided.
<"Arial" >
Boot: <"Arial" >Connect to the <"Arial" >Orange <"Arial" >wire <"Arial" >(pos.n°16) <"Arial" >in the Grey 40-pin connector on the BSI control unit.
<"Arial" >
<"Arial" >
ELECTRIC WINDOWS
<"Arial" >
The electric windows are only lifted by means of the comfort function (standard) using the original remote control.
08/03/2003 rev.00
<"Arial" >
PEUGEOT 307 2003 29.27.1
DIAGRAM OF CONNECTIONS FOR PROTECTION OF DOORS /BOOT
<"Arial" >
Fit diodes on the original vehicle wires as shown above. Refer to installation file 29.27
for their positions
MAIN CONTROL UNIT
Connect to
wire from
alarm for
protection
of doors
<"Arial" >
FRONT LEFT
FRONT RIGHT
REAR LEFT
REAR RIGHT
BOOT
Connect to wire from
alarm for protection of
boot
08/03/2003 rev.00
<"Arial" >
<"Arial" >
METHOD OF INSTALLATION FOR M750/9
FUNCTION COLOUR OF M750
WIRE
COLOUR OF
INTERFACE WIRE PIN CONNECTOR FOR
CONNECTION
DATA A VAN BLACK/ PURPLE BLACK/ PURPLE 4
DATA B VAN BLACK /RED BLACK /RED 6
<"Arial" >
Insert Black 6-pin
connector in position shown
in the diagram.
Protection: doors,
boot
<"Arial" >
The boot and door switches are normally read by the <"Arial" >Van line
The VAN line is able to provide all the information needed for operation of the M750/9 alarm by
means of the vehicle’s ALARMS VAN line.
To enable dialogue between the alarm control unit and the vehicle, you must ask the car dealer to
enable the ALARMS VAN line using the diagnostics tester.
The enabling of the ALARMS VAN line is essential for the operation of the M750/9 and can be
carried out either before or after installation of the product.
BLACK/ Purple
BLACK/ Red
BLACK/ Purple
BLACK/ Red
<"Arial" >
M750/9
