06 jeep grand cherokee stereo info
sacarmic
Member - Posts: 7
Posted: May 04, 2008 at 10:21 PM / IP Logged
Does anyone know where the RED / orange wire that is in the factory harness that carries 12v constant is fused? I'm not getting power to those wires and I don't see any fuses blown. I want to see if I can find specifically where it lands.
Thanks,
Scott
davngr
Copper - Posts: 109
Posted: May 05, 2008 at 1:40 AM / IP Logged
try checking under your hood, there should be a plastic box  with a lid. when you remove this lid you should find a few fuses.   with out konwing what kind of car/harness it's hard to tell you exactly.
life is a comedy to think, a tragedy to feel
sacarmic
Member - Posts: 7
Posted: May 05, 2008 at 5:17 AM / IP Logged
it is an 06 Grand Cherokee SRT
teenkertoy
Copper - Posts: 112
Posted: May 14, 2008 at 3:32 AM / IP Logged
If you don't find the fuse in the power distribution center located under the hood next to the battery, there should be another fuse block inside the car. I haven't looked at an '06, but most cars have one including the three jeeps in my family.
Try looking under the steering wheel, above the pedals. Or on the side of the dashboard facing either the driver's or passenger's doors, there may be a removable panel. Wherever it is, should be within reach and not too difficult to find. The owner's manual will certainly tell you where to look, if not tell you where that specific fuse is.
-Justin
Malcom: "This is the captain. We have a...little problem with our engine sequence, so we may experience some slight turbulence and then...explode."
Jayne: "We're gonna explode? I don't wanna explode.
sacarmic
Member - Posts: 7
Posted: May 14, 2008 at 7:07 AM / IP Logged
I did find it. It is in the front fuse block under the hood. It is fuse 28. It is in a weird holder that holds two fuses. You must remove both in order to get to this one fuse. it is the 20amp of the two.
Thanks,
Scott
Tuesday, March 17, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
