command start cs 395 i
denrich
Posted: May 10, 2008 at 6:52 AM / IP Logged
I have a  Command Start remote and the local Nissan dealer erased the transponder signal while programming a new key. Does anyone know how to reprogram it. It has a datalink modual under the dash.
Richie
tedmond
Gold - Posts: 4,610
Posted: May 10, 2008 at 12:28 PM / IP Logged
unplug harnesses to the datalink, hold the programming butotn, plug it back in and the light will light up green for programming mode. place keys into ignition and turn it on, the light will flash 3 times and you relearned it.
denrich
Posted: May 10, 2008 at 2:26 PM / IP Logged
Thanks , I tried it but didn't work so played around with it like your instuctions and found out that the light had to be red flashing at first when connecting harness  and then constant red for learning and didn't become green but flashed green once when learned. I have the Datalink ADS-AL (128) . Now working command start cs 395 i -- posted image.
Richie
