do i need to fuse?
DYohn
Platinum - Posts: 10,741
Posted: May 22, 2008 at 11:36 AM / IP Logged
I would fuse it right at the battery terminal.
KPierson
Platinum - Posts: 3,527
Posted: May 22, 2008 at 12:58 PM / IP Logged
I, too, would fuse it.  I would route the amp power wire along side the feed wire and install the fuse holder behind the battery, next to the other fuse holder.
Kevin Pierson
Platinum - Posts: 13,726
Posted: May 22, 2008 at 8:27 PM / IP Logged
There are no fuses inside the amp.  If they are not mounted on the endcap that your battery is blocking the view of, it does  not have one.
As stated above YES you need to put a fuse between the battery and the amp.
Just trying to stop you before you disassemble the amp.   I know for a fact that there are no fuses inside the amp.
audiocableguy
Copper - Posts: 630
Posted: May 23, 2008 at 5:09 PM / IP Logged
This is a cool new fuse set up:
http://bluesea.com/category/5/21/productline/overview/378
audiocableguy
Copper - Posts: 630
Posted: May 23, 2008 at 5:13 PM / IP Logged
Before you think I'm truely crazy, the fuse design explains the above terminal block. Pretty simple and fits in small spaces.
haemphyst
Platinum - Posts: 5,059
Posted: May 23, 2008 at 7:56 PM / IP Logged
DUDE!!! That is sweet!
audiocableguy
Copper - Posts: 630
Posted: May 23, 2008 at 8:54 PM / IP Logged
The Terminal Fuse Holder is $20 and the fuses are $16. These $$$ are from West Marine which leads me to believe they can be found cheaper other places.
