04 honda odyssey sec interface
albertatech
Member - Posts: 36
Posted: May 31, 2008 at 12:03 PM / IP Logged
I am installing a Viper 5900 and the XK02 instructions indicate a "Data wire (thin Brown wire) on a female connector located from driver door, wire side of fuse box, pin A15." I cant find this wire. Is there another data wire that will for sure work? Pin 2 on the ALDL OBDII connector isnt there, no pin 2 and its too old for CAN bus. Some modules connect to the cylinder but this one calls for behind the fuse box.
jmsounds
Copper - Posts: 99
Posted: May 31, 2008 at 12:57 PM / IP Logged
i use fortin and the instruction says you can find the wire at the transporder key connector  data  i done a few hondas and will always be there  the data wire is BLUE/GREEN  PIN #2    good luck
JWorm
Platinum - Posts: 2,208
Posted: May 31, 2008 at 1:16 PM / IP Logged
Wiggle the harness in the drivers door jam. Can you see where that harness goes into the car? Its in that harness.
albertatech
Member - Posts: 36
Posted: May 31, 2008 at 4:04 PM / IP Logged
I HATE door harnesses... lol. Thanks for the tips, should get it now.
