03 rsx, viper 5900, 556u bypass
nbboy7
Member - Posts: 19
Posted: June 09, 2008 at 3:20 PM / IP Logged
Ok i put in viper 5900 and 556u imoblelizer bypass. But it don't send a singnal. I wanted to know the if i hook it up right. I have the red,blue and black wires hooked up. I'm also not so sure on where to mount the ring.
Mike M2
Platinum - Posts: 2,652
Posted: June 09, 2008 at 8:32 PM / IP Logged
If you don't mount the ring it isn't going to work. The ring goes around the ignition switch just under the shroud. The wiring is simple, red to 12volts, black to ground, and blue to the blue statis wire on your 5900....
Mike M2
Tech Manager
CS Dealer Services
