woofers flexing?
elmaschingon_18
Member - Posts: 21
Posted: July 22, 2008 at 11:05 AM / IP Logged
Do any of you guys know what it means when woofers flex before playing. It happens when i change songs they'll pop without noise and as soon as the radio turns on. Weird....is my tuning off. its a ported box
sanding sucks!
megaman
Copper - Posts: 385
Posted: July 22, 2008 at 11:49 AM / IP Logged
If it pops when you change songs, it's most likely your headunit.
elmaschingon_18
Member - Posts: 21
Posted: July 22, 2008 at 12:57 PM / IP Logged
I think the HU is okay. I heard turn thump before and it doesn't sound like it. I know i didn't explain it right before, The woofers don't pop at all they move in and out once. It's a flex in the woofers! they move in and out once and then the song starts.  It's like when you tune/play with LPF the woofer starts moving irratically! i think thats the best i can describe it. When the woofers start to play it's fine. Do you guys think it's the slot plot?
sanding sucks!
lspker
Silver - Posts: 503
Posted: July 24, 2008 at 9:48 PM / IP Logged
Not likley the port.  if the woofer starts moving before the music there must be an issue else where.
Try dissconnecting there rvc, try input from different source.
Platinum - Posts: 13,724
Posted: July 24, 2008 at 10:13 PM / IP Logged
Does your subwoofer amp have a Subsonic filter?  If so turn it on.
Turn the gain of the sub amp all the way down.  Does it still move when you change songs?  If no can you still achieve your desired listening level?
