VSS Wire 08 Honda Civic
waynel
Posted: July 25, 2008 at 10:24 AM / IP Logged
08 honda civic using xk601 module from Bypasskit.com. If vehicle is  ordered without a radio the vss wire called for in the instalation manual is not there.  Going to the radio plug (it is taped to the back of the radio hole cover) for the vss as  the instructions indicate does not work, the wire is there but is dead.  The alternate VSS wire location is in the engine compartment.  To remove the computer and access the wire you need to remove the battery, take the black plastic cover off of the computer.  remove 3 metric bolts holding the computer in place. The connector with the correct blue wire was in the plug closest to the front of the vehicle.
wayne/trilogix
Monday, February 9, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
