03-08 dodge truck, aftermarket tachometer
aer_david
Posted: July 27, 2008 at 2:42 PM / IP Logged
there are conflicting arguements to wire an aftermarket tachometer in a 2003-2008 dodge truck with a 345 hemi the 6 cylinder model requires an adpter offered by each manufactueer, but i have yet to find out can the tach be wired directly to the existing factory tach , and what wire should be used.
benzo33
Copper - Posts: 87
Posted: July 27, 2008 at 5:27 PM / IP Logged
You should get a Haynes manual to look for the wiring diagram. That's how I figured out to wire my head unit and nav system.
2001 Corolla S and 2005 Neon SRT 4 ACR.
Phreak480
Copper - Posts: 84
Posted: July 27, 2008 at 6:09 PM / IP Logged
its not going to be in the haynes manual for that truck. i have an 03 ram with the hemi. i suggest you do a little online research and you can find places to download the service manual for free. unfortunately i'm sure i would not be allowed to post a link on here as it is in effect "stolen" but not very difficult to find either. i have seen both the 03 and the 04 manual for download
aer_david
Posted: July 27, 2008 at 7:25 PM / IP Logged
thanks, for the help, i'll see what i can find.
Platinum - Posts: 13,725
Posted: July 27, 2008 at 8:33 PM / IP Logged
Tachometer dk. blue/gray   ac   PCM, BLACK/ orange plug, pin 34
Notes: The PCM is on the passenger side firewall. The BLACK/ orange plug is the second plug down from the top.
You may have that same color wire at the instrument cluster.  If so check it with a volt meter to verify that the AC voltage increases with the increase of RPMs.
Wednesday, March 11, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
