viper alarm issue
boofin
Posted: August 24, 2008 at 11:41 PM / IP Logged
I have a viper 690xv alarm on a 92 honda accord. When the alarm is armed and I open the door my remote shows "door" just as it should. Then when I hit unlock it shows "door," letting my know my door was opened. I then arm my car again, I DONT open the door and hit unlock and it still shows "door" even though the door has not been opened since the previous time. What causes this? Thanks
kgerry
Platinum - Posts: 3,455
Posted: August 25, 2008 at 10:54 AM / IP Logged
did you cycle the ignition to clear the "event memory"?
Kevin Gerry
MECP First Class Installer
Owner/Installer
Classic Car Audio
since 1979
boofin
Posted: August 25, 2008 at 2:36 PM / IP Logged
No I dont think I did. I only have my door trigger, door unlock/lock hooked up. Which is the way I want it. So if I hook-up the ignition wire to the cars ignition it clears the memory? Thanks
Posted: August 25, 2008 at 3:31 PM / IP Logged
If you don't hok the yellow? ign input to ign, a) It won't recycle as above and B) You're alarm will work even with ign ON. Very embarrasing for you if you made an immobiliser cut.
boofin
Posted: August 25, 2008 at 4:59 PM / IP Logged
Well I hooked up the ignition input and thats solved the probelem. Thanks guys!
Saturday, January 31, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
