speaker wire gauge
enigmacarpc
Posted: August 25, 2008 at 1:37 PM / IP Logged
I have a quick question.
The work to remove my 20 gauge stock speaker wire and replace it with 12 gauge seems to labor intensive I have an 2005 Infiniti G35 Coupe.
Can I use the stock speaker wire it will be connected to a mid 150 RMS and 300 max watts the speaker wire runs are 15ft and 22ft.
I seem to be getting mixed answers around the internet.
DYohn
Platinum - Posts: 10,741
Posted: August 25, 2008 at 4:50 PM / IP Logged
Why do you want to use 12 AWG?  You need no more than 16 AWG.  In any case, I do not recommend more than 50 wpc using factory wiring.
enigmacarpc
Posted: August 25, 2008 at 10:24 PM / IP Logged
Is it a heat issue or sound?
It seems like most people go with the 12 awg.
Are you sure 16 awg is enough at 300 watts per channel?
audiocableguy
Copper - Posts: 630
Posted: August 25, 2008 at 11:23 PM / IP Logged
16 AWG is fine for 300W. No you don't need any special oxygen free blah blah blah. Monster is marketing BS. Lamp cord will work.
enigmacarpc
Posted: August 26, 2008 at 12:43 AM / IP Logged
I know monster cable is a rip off I'm going to get the StreetWires 14 AWG speaker wire 50ft for 22$.
I still want to know is running 150 RMS on 20 AWG a heat problem or sound problem?
haemphyst
Platinum - Posts: 5,059
Posted: August 26, 2008 at 12:54 AM / IP Logged
The issue is this: resistance. Too much of it will reduce the amount of power being delivered to the speaker, as well as having a detrimental effect on damping.
So, yeah... I guess "sound". You will pass the point of diminishing returs almost instantly once you pass over #16 wire, at a 4 ohm load.
reax222
Copper - Posts: 220
Posted: August 26, 2008 at 2:32 AM / IP Logged
300=e(e)/4.    So about 34volts total. about 8.8amps running through the wires max. 16ga should be a champ.
enigmacarpc
Posted: August 29, 2008 at 9:22 PM / IP Logged
