pioneer avh blacks out
dbe88
Posted: August 28, 2008 at 6:34 PM / IP Logged
I have a avh-p6500 dvd, when the screen is closed the deck completly blacks out, get sound but cannot control anything, no lights etc. if i remove the face plate and reattach everything works fine but then blacks out again usually over bumps. now if the screen is open it is starting to happen too. screen will shut off same symptoms. do the ribbons work loose?
ae2(aw)
Platinum - Posts: 13,724
Posted: August 28, 2008 at 7:05 PM / IP Logged
CNP8807      FLEX CABLE FROM LCD MONITOR      IN STOCK        $35.39        Pacific Coast Parts pacparts.com 1-800-421-5080
This not an easy repair for a novice. There may be instructions to change it on the web. You will have to look for them.
