1993 landcruiser 9 sp system
madbillygoat
Posted: September 11, 2008 at 3:06 PM / IP Logged
Hello,
I have looked up my 93 toy. landcruiser,  and The wiring for my audio system " 9 sp. " is not there 1993 landcruiser 9 sp system -- posted image.. The standerd 4 sp system is listed but not mine.. 1993 landcruiser 9 sp system -- posted image.
I have also found that the rear door speakers are 4 in not 6.5. I dont knwo who I tell for the correction??1993 landcruiser 9 sp system -- posted image.
My problem.  1993 landcruiser 9 sp system -- posted image.  I am using my oem amps and upgrading my speakers and subwoofer.  The problem is that I need to know what the wire colors for the sub amp in back are..1993 landcruiser 9 sp system -- posted image.   I need the preamp wires so I can hook them up directly to my Rec.  If someone has the wire coding for the whole system that would be great.
Thanks for eveyones help !!  1993 landcruiser 9 sp system -- posted image.
Mad Billy Goat ..   "Plague"
Installer_mss
Copper - Posts: 221
Posted: September 12, 2008 at 11:14 PM / IP Logged
there is only one amp in your truck and it's for the sub.  all the other speakers run off of the radio.  the rear roof and door speakers are just hooked together off the same wires (splits off from the radio to both speakers on each side) i.e. left roof speaker and left rear door speaker are connected.  same with the front door and dash speakers.  here are all of the wire colors at each speaker from alldata's schematics:
(first color is pos, second is neg)
subwoofer = lt. GREEN/ red & lt. GREEN/ black
Lt Roof Sp = yellow & black
Lt Rear Sp = white & red
Rt Roof Sp = white & red
Rt Rear Sp = white & red
Lt Fr Door Sp = blue & lt. green
Lt Fr Dash Sp = purple & pink
Rt Fr Door Sp = blue & lt. green
Rt Fr Dash Sp = blue & lt. green
"If a man made it, another can modify it...it just takes some thinking."
"If you ask questions, you're a fool for 5 minutes; if you don't, you're a fool for a lifetime."
madbillygoat
Posted: September 13, 2008 at 12:56 AM / IP Logged
Hello,
Thank you for your responce.. 1993 landcruiser 9 sp system -- posted image.  The amp for the rest of the speakers is located behind the pasanger 3.5" speaker in the dash.  My Reciever is only preamp there are no speaker outputs on my eclipse.
The wire codes you have me. Are they for the preamp of the rear amp. or the Speaker connected to the amp.
Thire are two wires going to sub.. but there are about 6 or 8 wires connected to the other port.  I was wondering if anyone know which 4 are the preamp. and Where they are connected at the front end?
Thank you for your help. 1993 landcruiser 9 sp system -- posted image.
Nick
