adding keyless to 96 f150
aperez70
Posted: September 14, 2008 at 12:05 PM / IP Logged
hello all. I purchased a python alarm with keyless for my 96 f150 xlt with powerlocks and no factory keyless. i have the alarm installed and am tring to wire up my keyless. i found the wires in the passenger kick panel and cut them . hooked up my alarm wirng to the wires and nothing works. i pop a fuse (s) ..is there a wiring diagram that can show me what wire goes where???? thanks
KarTuneMan
Platinum - Posts: 7,056
Posted: September 14, 2008 at 12:43 PM / IP Logged
the connections you made are backwards. On the wire you cut, you have the switch side, and the motor side. the wires from your unit/relays.... switch them
adding keyless to 96 f150 -- posted image.
