2003 lancer audio wiring
filharmonics
Posted: September 30, 2008 at 5:18 PM / IP Logged
I went to install an aftermarket stereo today in my 2003 Lancer, but got really confused when none of the wires were making logical sense. I searched as many forums as I could find to get answers to this question, but found none until I found this site. However, there isn't any info about 2003 lancer audio, is it the same as the galant?
kassdog
Copper - Posts: 257
Posted: September 30, 2008 at 5:41 PM / IP Logged
Are you using a wiring harness if you are it should be pretty straight forward. If your not I would highly recremend getting one. You can pick on up at any car audio shop/big box store/walmart for roughly $20. It will make your installation a lot nicer and easier.
filharmonics
Posted: September 30, 2008 at 8:14 PM / IP Logged
Okay thanks I'll look into it further. The harness I was talking about was the existing one, and i hadn't thought about a harness to replace the one that doesn't fit on my replacement stereo.
spec auto
Member - Posts: 6
Posted: September 30, 2008 at 8:15 PM / IP Logged
what do you mean doesnt make sense, if your not using a wire harness, are you using the correct speaker wires/ign wires, that car also has the possibilty of a factory amplifier and in that case, theyres no way you gonna get it going using your galant tactics...
should be standard colors
yellow/red   greay/ red FR
yello/blue   gray/blue FL
WHITE/ red     BLACK/ blue RR
WHITE/ blue    black blue  RL
Acc usually solid blue and 12+ is usually RED / black
these are standard colors for mitsu, but they are always changing for newer cars..
spec auto
Member - Posts: 6
Posted: September 30, 2008 at 8:16 PM / IP Logged
thats WHITE/ red   black red for the RR
always test your sires first though..
Tuesday, October 28, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
