car not starting properly when left overn
linedriver
Member - Posts: 17
Posted: October 10, 2008 at 4:23 PM / IP Logged
btw, i forgot to mention that the skylines ignition harness is basically the same as the S13 240sx wiring harness for the ignition. alot of the things are the same color, just different places
Mike M2
Platinum - Posts: 2,652
Posted: October 10, 2008 at 4:59 PM / IP Logged
What the point of a second starter wire is has been debated here before. If it isn't connected and you have one, hook it up!!!!
Mike M2
Tech Manager
CS Dealer Services
linedriver
Member - Posts: 17
Posted: October 10, 2008 at 5:11 PM / IP Logged
ill hook it up to the 5th relay. in the wiring diagram, it says its 'ignition 2', but from what ive read so far, it only needs power momentarily to be able to start up while its cold since it activates a cold valve or something. should i jumper it to the ignition pin, or the crank pin since it only needs a moments worth of juice?
moonliter
Copper - Posts: 322
Posted: October 10, 2008 at 5:33 PM / IP Logged
Use the green wire ( 5th relay, which is programmable either for ign2, acc2 or starter2 ) and connect it to the second starter wire in the vehicle. Just move the jumper from the middle to the left when you are looking at the back of the module.
Sunday, April 28, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
