securelock bypass, 2003 navigator
htrdlicn
Posted: November 18, 2008 at 10:14 AM / IP Logged
In this old thread, instructions are given for bypassing PATS using a relay and wire. (clever)
https://www.the12volt.com/installbay/forum_posts.asp?tid=1719
Will this work with Securelock found on my 2003 navigator.
I found out the hard way that the DEI 555f does not work...
Thanks for any pointers.
Jason
ckeeler
Gold - Posts: 1,461
Posted: November 18, 2008 at 11:08 AM / IP Logged
yes it will work
Mike M2
Platinum - Posts: 2,652
Posted: November 18, 2008 at 3:40 PM / IP Logged
My pointer to you is go buy the proper bypass. The 556S works fine, so does the FLTB1 from Idatalink...
Mike M2
Tech Manager
CS Dealer Services
ckeeler
Gold - Posts: 1,461
Posted: November 18, 2008 at 3:54 PM / IP Logged
i also suggest that. in direct answer to your question, yes it will work, but, i also recommend just purchasing the correct module.
chriswallace187
Gold - Posts: 1,661
Posted: November 18, 2008 at 6:46 PM / IP Logged
Ditto with the others that you should purchase a module instead of messing with a relay. Also I'd suggest a data module of whatever brand - 2 wires to the car, 3 to the remote start, and no worrying about Ford's RF-insensitive immobilizer modules.
C Renner's Auto Electronix
kgerry
Platinum - Posts: 3,455
Posted: November 19, 2008 at 9:12 AM / IP Logged
XK04 from Bypasskit
Kevin Gerry
MECP First Class Installer
Owner/Installer
Classic Car Audio
since 1979
