amp pass thru
1nicemustang
Copper - Posts: 89
Posted: March 15, 2003 at 7:07 AM / IP Logged
looking into some amplifier options ive noticed some with rca pass thru options. i take it that this is an unamplified full range signal supposedly used for connecting another amp?
what would the benefits be of this feature and has anyone used it before?
bberman1
Gold - Posts: 2,314
Posted: March 15, 2003 at 10:23 AM / IP Logged
You have it correct it’s just a normal  unamplified signal pass thru. It’s used for system building. I f you need to run more than one sub amp you would get the signal to the 2nd one using the RCA output on the first amp. I have used it before and it works great much better than adding a Y adapter to get 2 amps off 1 signal.
wvsquirrel
Gold - Posts: 1,237
Posted: March 17, 2003 at 10:23 PM / IP Logged
Be careful if you do this with Rockford Power BD class amps. They require a bdSYNC cable when joining multiple amps using the RCA passthrough. They also have a Punch Link that's supposed to be used to join multiple amps (power, ground, input signal) but I'm still trying to find more info on them. But I am sure that the Power BD series amps require the bdSYNC cable when using the RCA passthrough (and 1 amp needs to be set to 0 degrees phase, the other at 180 degrees phase)
Squirrel
"No more Cpt. Kirk chit chat"
Donate to the12volt.com
dragonrage
Copper - Posts: 193
Posted: March 18, 2003 at 6:15 AM / IP Logged
wv: that's for using multiple amps for one output. Of course you don't need them if they are for seperate speakers.
2009 Pontiac G8 in planning stage
HU: ?
Speakers: ?
Amps: ?
wvsquirrel
Gold - Posts: 1,237
Posted: March 18, 2003 at 7:21 AM / IP Logged
Cool, I wondered why RF made the bdSync cable and the link. I wasn't sure if the Punch Link was just the bdSYNC for non-BD class amps. Makes sense now. Thx
Squirrel
1nicemustang
Copper - Posts: 89
Posted: March 18, 2003 at 1:18 PM / IP Logged
so let me get this straight........its an unmaplified stereo signal then....so it owuldnt be crossed over at all from the first amp in any way.and the left and right channels would operate the same as if connected to a HU?
dragonrage
Copper - Posts: 193
Posted: March 18, 2003 at 2:46 PM / IP Logged
Yes, that's how they work, or most of them anyway.
HU: ?
Speakers: ?
Amps: ?
