Power lock wires
RaveChild
Copper - Posts: 54
Posted: March 15, 2003 at 5:17 PM / IP Logged
I am trying to install an autopage rs750 in my 1996 sunfire gt with keyless entry.  According to the wiring guide, my power lock wire is lt. blue and unlock is white, they are located in either kick pannel.  I have found two of each color in the drivers kick pannel that go into a black and blue harness.  How do I now if these are the wires I need, and which one do I tap into??
RaveChild
Copper - Posts: 54
Posted: March 16, 2003 at 5:52 AM / IP Logged
no one can help me??
Platinum - Posts: 12,488
Posted: March 16, 2003 at 3:59 PM / IP Logged
Use a DMM or light tester on the target wire and toggle the lock/unlock switch. When you ground the DMM or light tester & toggle the switch, it should register a voltage. If it does, then that's the correct wire. If not, then try the other wire.
