negative effects of narrow enclosure?
sound
Member - Posts: 14
Posted: December 03, 2008 at 11:54 AM / IP Logged
   How narrow can a portion of an enclosure be before it negatively affects the preformance of a sub? I want to put a sub into an area that is not big enough for a correct sized enclosure, however the enclosure could be extended into another area by a narrow passage/channel of some sort. Maybe the internal dimensions of the channel would be .75 by 5 by 5 inches.
DYohn
Platinum - Posts: 10,741
Posted: December 03, 2008 at 12:09 PM / IP Logged
In general, the geometry of a subwoofer enclosure does not matter.  It is the net airspace volume that matters.  So go ahead and make it whatever odd shape you need to.
sound
Member - Posts: 14
Posted: December 03, 2008 at 1:12 PM / IP Logged
   ok.  I was thinking more in terms of air movement inside the sub being constricted or choked rather than the actual geometry.
DYohn
Posted: December 03, 2008 at 1:50 PM / IP Logged
Not an issue.
sound
Member - Posts: 14
Posted: December 03, 2008 at 1:54 PM / IP Logged
  Alright!   Thank you for the info.
