2005 buick terezza
Welcome Guest :)
jkyliej
Copper -
Posted: December 22, 2008 at 4:58 PM / IP Logged
All,
Looking for the vehicle wiring for a 2005 Buick Terezza. I searched the forum but only found one post where someone had put up some wiring codes but it was a little vague. Hoping since then someone has done one and can post the wiring chart.
Thanks.
jkj
ceasar326
Copper -
Posted: December 22, 2008 at 5:13 PM / IP Logged
2005 Buick Terraza | Last Update: 11/13/2008 | < name=print =wiresprint.asp>< = value=7863 name=recnum> < class=submit =submit value=PRINT name=printsubmit> | > |
| Circuit | | Wire Color | | Location | | |
Constant 12 volts | RED or RED / BLACK AT | BCM C1 PIN 51, BATTERY OR FUSE BOX |
Ignition 12 volts | PINK | AT BCM, C1, PIN 22 * |
Starter | YELLOW | AT BCM, C1, PIN 21 * |
Dome Light | GRAY/BLACK (-) | AT BCM, C1 PIN 43 * DOOR PINS ** |
Trunk Pin | LIFT GATE (-) | AT BCM, C2 PIN 3 * |
Parking Lamp | BROWN (+) FUSE BOX OR | PASS KICK HARNESS TO REAR (SEE TECH) |
Lock | PINK/BLACK IN DRIVER | KICK OR AT BCM C2 PIN 2 * #201 |
Unlock | ORANGE / BLACK IN DRIVER | KICK OR AT BCM C2 PIN 11 * |
| | #201- See Negative Pulse Door Lock Diagram. * See Tech On Location And Connectors. ** The Drivers Door Is A GRAY/BLACK (-) Pin 26, The Pass Door Is A TAN/WHITE (-) Pin 17, The Drivers Rear Door Is A L BLUE/BLACK (-) Pin 7 And The Pass Rear Door Is A L GREEN/ BLACK (-) Pin 5.Diode Isolation Is Required. | |
| Tach Signal | | ORANGE / WHITE | | IN LARGE HARNESS ABOVE ENGINE #239 | | |
Ignition #2 | | |
Ignition #3 | | |
Accessory | BROWN | AT BCM C1 PIN 23 * ** |
Neutral Safety | NA | |
Brake Light | WHITE (+) | AT BCM C1 PIN 30 * |
Reverse Light | L GREEN (+) | AT BCM C2 PIN 42 * |
Rear Defrost | WHITE (-) | AT BCM C2 PIN 16 * |
| | #239 See Immoblizer Bypass System * See Tech On Location And Connectors. ** Additional Accessory Wire BROWN Is Required. If Not Powered You Will Get A Pass Lock Light and vehicle will not start. In Addition To This The GREEN Key Sense Wire Must See A Ground When Running. If Not The Service Required Light Will Come On. Its The Light With The Car And Wrench On It. | |
| Window Up | | - | | D\D BLUE P\D BLUE AT SWITCH IN #211 | | |
Window Down | - | D/BROWN P/BROWN DRIVERS DOOR |
Keysense | LT GREEN (-) | AT BCM C1 PIN 40 * |
Trunk Release | D GREEN (-) | AT BCM C2 PIN 3 * |
OEM Horn | TAN (-) | AT BCM C1 PIN 4 * |
Headlights | TAN/WHITE (-) | AT BCM C1 PIN 7 * |
OEM Alarm Arm | | |
OEM Alarm Disarm | PURPLE (-) | AT BCM C2 PIN 24 * |
| | #211- See Reversal Rest At Ground Power Window Circuit Diagram. * See Tech On Location And Connectors. OEM Hood Pin: PINK/BLACK (-) At BCM C1 Pin 26 Right Sliding Door: L BLUE (-) At Roof Console Left Sliding Door: L BLUE/BLACK (-) At Roof Console | |
| OEM Keyless Module | | - | | UNDER DRIVERS DASH BUILT INTO BCM | | |
Motor Lock | GRAY | AT BCM * CONN C2 PIN 52 |
Motor All Unlock | TAN | AT BCM * CONN C2 PIN 51 |
Motor Driver Unlock (disarm defeat) | TAN | AT BCM * CONN C2 PIN 48 |
OEM Lock Relays | - | BUILT INTO B.C.M. |
Add On Security Type | - | #5 CONNECTION #225 |
| | #225 See AL-100/VIP-4000 Type 5 Diagram * See Tech On Location And Connectors |
jkyliej
Copper -
Posted: December 23, 2008 at 9:00 AM / IP Logged
Thank you, I appreciate it.
jkj
Friday, May 10, 2024
• Copyright © 1999-2024 the12volt.com, All Rights Reserved
• Privacy Policy & Use of Cookies
