auto timer, tach, 08 fit
tedmond
Gold - Posts: 4,610
Posted: December 30, 2008 at 8:55 AM / IP Logged
haha, i was just going to mention if he couldnt find it, run it out to the engine bay and look for the odd colour at the injectors and splice into it.
hulk88
Member - Posts: 8
Posted: December 30, 2008 at 4:33 PM / IP Logged
tedmond wrote:
Battery (+) - WHITE
Ignition (+) - BLACK / YELLOW
Accessory 1 (+) - YELLOW/BLACK
Accessory 2 (+) - WHITE/ RED
Starter (+) - BLACK/ WHITE
did you even test the wires? or did you just splice into the wires?
Sir, i think you dun get what i mean...
the colour stated at my steering column does not have the colour code you state.
i have state the colour that was there in my post eariler...
my wire are all in single colour...
tedmond
Gold - Posts: 4,610
Posted: December 30, 2008 at 11:12 PM / IP Logged
i crossed referanced my wiring charts and those wires are the ones that should be at the steering column. pop the shroud off and unplug the harness comming from the ignition switch. I know on some hondas, from the ignition switch down to mid knee kick panel, the harness is plugged into another harness and changes colour. Make sure you got the right wires. dont want to burn ou ta turbo timer.
