viper 5900 in 05 mustang gt
truckie117
Posted: December 28, 2008 at 9:03 PM / IP Logged
Hi
I am starting to install a viper 5900 and its been awhile. This is the first remote start. does anyone have a good place to put the brain and then the XCRS relay satelite. Do you have to cut the wires to the ignition and insert the relay into the circuit or just tap into the circuit? the wires are huge and the wires to the key switch so small.
I went to the wiring page and downloaded the color code. I have a bypass
Mike
ckeeler
Gold - Posts: 1,461
Posted: December 29, 2008 at 2:34 PM / IP Logged
you will need to cut the starter wire unless you dont use the anti-grind. for all wires, including the starter wire, solder them from the relay pack into the ignition harness. dont use t-taps, not only are they poor at conducting electricity, they fall off.
truckie117
Posted: December 29, 2008 at 8:23 PM / IP Logged
I will be posting pics as the install progresses
Tuesday, March 17, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
