2000 silverado, remote start
irontrent
Posted: January 11, 2009 at 3:56 PM / IP Logged
I am having trouble locating the tach wire on my 2000 Silverado. I have checked the "white" wires that are on the steering column. None of them show 1 to 6 volts AC. I am not sure where to look under the hood. Any help will be greatly appreciated.
Thanks in advance
- Trent
- Trent
loneranger
Copper - Posts: 572
Posted: January 11, 2009 at 3:59 PM / IP Logged
Tach will be at the coil.
Ideal - cmon dude, add to topics in a useful manner, not stuff that is obvious.
Story - Phzzzt! Hey, what happened?! ... Isn't it obvious?
Moral - Never dismiss the obvious.
irontrent
Posted: January 11, 2009 at 4:00 PM / IP Logged
Apparently I am unable to follow instructions...can someone help me understand how to program the Valet 651T? I understand how to get to the different options, but don't understand how to use the inputs to change the values. I only hooked up the negative input, that interfaces with my Viper 300 ESP alarm's Channel 3 negative output. Do I need to also manipulate a positive input to program the Valet?
- Trent
- Trent
irontrent
Posted: January 11, 2009 at 4:02 PM / IP Logged
Talk to me like I'm a two year old. Where is the coil and how do I find the wire there?
Thanks for you help.
- Trent
Mike M2
Platinum - Posts: 2,652
Posted: January 11, 2009 at 4:03 PM / IP Logged
Get the tach behind the instrument cluster, white wire. Pop off the bezel and remove the 4 7mm screws, very easy to get to....
Mike M2
Tech Manager
CS Dealer Services
loneranger
Copper - Posts: 572
Posted: January 11, 2009 at 4:23 PM / IP Logged
I'm not familiar with a Valet 651T.
CutDog504
Silver - Posts: 643
Posted: January 11, 2009 at 5:43 PM / IP Logged
I agree with Mike. Easiest place is right behind the cluster, the harness that plugs into the intrument cluster has a white wire which is the tach wire you're looking for. This is where I grab it on every GM full size truck and SUV.
irontrent
Posted: February 17, 2009 at 11:07 AM / IP Logged
I am beating my head against the wall with this thing. When I used to install, I always thought of these as the easiest vehicles to work on...
I have a Valet 561T remote start, with a 555L Passlock Interface. I am still getting the security light flashing at me when it attempts to start the truck. I started it with the key and let it run for about 1 minute, the 555L book said it only needs 15 seconds.
I hooked the Yellow wire on the 555L to the Code-Producing Side (Coming from the Key) of the Yellow passlock wire. The Black-Yellow wire on the 55L to the non-Code-producing side (going down the column towards the firewall).
The black wire on the 555L is hooked to the ORANGE / black wire coming down the column (the Passlock ground reference).
Please tell me what I am doing wrong.
- Trent
CutDog504
Silver - Posts: 643
Posted: February 18, 2009 at 1:41 PM / IP Logged
did you ground the neutral safety switch input?
irontrent
Posted: February 20, 2009 at 7:14 AM / IP Logged
Yes, but would that cause the factory security system to kick in? One thing I thought might be it, do I need to diode isolate the negative trigger on the 555L? Right now, I have the negative trigger coming out of the Valet Remot Start module going to both the Viper alarm and the 555L.
- Trent
- Trent
Friday, September 12, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
