alternating horns wiring for alarm system
lcolson
Member - Posts: 18
Posted: January 12, 2009 at 6:43 PM / IP Logged
I have an aftermarket alarm system in my truck. When the alarm is activated,  it sends a pulsating - (Negative) Signal to my factory horn. It sends an "On - Then Off Signal" I want to add an electric air horn to the output signal from the alarm. After the alarm sends out the Negative pulse and honks my factory horn, I want it to then honk the electric air horn. In other words, alternate between the Factory horn, then the Electric Air Horn. When the alarm is in the neutral pulse after honking the factory horn, I need it to then honk the electric air hor. Can someone grive me a type of relay or a wiring diagram to hook up to this pulsating Negative signal to acheive this outcome?
L Colson
loneranger
Copper - Posts: 572
Posted: January 12, 2009 at 6:54 PM / IP Logged
Sure. I need the year-make-model of the vehicle and the make-model of the aftermarket alarm,
Ideal - cmon dude, add to topics in a useful manner, not stuff that is obvious.
Story - Phzzzt! Hey, what happened?! ... Isn't it obvious?
Moral - Never dismiss the obvious.
lcolson
Member - Posts: 18
Posted: January 12, 2009 at 6:58 PM / IP Logged
I have a 2008 Ford F 250 Super-Duty with an IC Dynamics RS111-4500 Remote/Alarm System.
lcolson
Member - Posts: 18
Posted: January 12, 2009 at 7:00 PM / IP Logged
When I said REMOTE/ALARM; I mean Remote Start/Alarm
loneranger
Copper - Posts: 572
Posted: January 12, 2009 at 7:05 PM / IP Logged
I need a wiring diagram for the IC Dynamics RS111-4500. I can not find the product.
lcolson
Member - Posts: 18
Posted: January 12, 2009 at 7:16 PM / IP Logged
Why is that necessary? the horn output signal from the alarm is (-) 500mA. This wire is hooked up directly to the (-) horn output wire for the truck. It honks the horn "Honk, pause, Honk, pause, Honk, pause". All I want is something that when the negative signal is neutral, I can sent a (-) or (+) signal VIA relay to the Air Horn.
LC
Platinum - Posts: 13,725
Posted: January 12, 2009 at 7:23 PM / IP Logged
Does the alarm have a siren output along with the horn out wire.  If so this can be done with a couple relays.  Going to give this a shot without having to draw a diagram.
Relay 1  30 to the battery via a 15 amp fuse.  87 to the siren and also to 30 and 86 of relay #2.    Relay #1 continued, 85 to ground.  86 to siren out wire of alarm system.   Wiring for relay #2  30 is already connected,  87A to Compressor.  86 is already connected to power.  85 to negative horn output wire from alarm along with the horn wire of the vehicle.
Any time the siren is going off and the horn is not, the air horns will be.  If the air horns are not going off, the horn is.
Let me know if you need the picture.
lcolson
Member - Posts: 18
Posted: January 12, 2009 at 8:01 PM / IP Logged
Yes the alarm has a siren output, but I do not want alternate the siren output. I only want the alternate the horn output. When the alarm is honking the alarm, the horn honks then stops, then honks , then stops. When the Horn is "Not honking" the factory horn, I want it to honk the electric Air horn; so there is a constant honking of horns. What I want is Factory Horn, Air Horn, Factory Horn, Then Air Horn ect.....
Thanks,
LC
loneranger
Copper - Posts: 572
Posted: January 12, 2009 at 8:28 PM / IP Logged
lcolson wrote:
Why is that necessary? the horn output signal from the alarm is (-) 500mA ...
Well, there is one wire down. Now I will need to know if the alarm has a GWA output?
lcolson wrote:
... It honks the horn "Honk, pause, Honk, pause, Honk, pause" ...
I'm sure it does.
lcolson
Member - Posts: 18
Posted: January 12, 2009 at 8:30 PM / IP Logged
Yes, I thought I already stated that.
Page of 4
Tuesday, March 31, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
