viper 160xvl remote start wiring
advanced
Copper - Posts: 207
Posted: January 17, 2009 at 11:28 AM / IP Logged
5 Wire Alternating 12 Volts Positive Door Locks
Like the configuration above, the switch, when moved in either direction, applies both power and ground directly to motor legs  without the use of any relays. Except, at the switch in this case, both motor legs rest at ground . Therefore it is only necessary to change the polarity of one motor leg to lock or unlock the vehicle.
viper 160xvl remote start wiring - Page 2 -- posted image.
Good Enough Isn't!
94silverado
Member - Posts: 6
Posted: January 17, 2009 at 9:19 PM / IP Logged
just wanted thank those who gave their advise. it made this install go easy. you guys know what you are doing.
great forum
