2009 Dodge Ram Alarm Wiring
jsanchez71
Member - Posts: 28
Posted: January 18, 2009 at 12:01 PM / IP Logged
Hi there, does any body have the wiring diagram for this truck, i will be installing a 5900 from viper. Any help will be appreciated.
robertsc
Copper - Posts: 337
Posted: January 18, 2009 at 12:21 PM / IP Logged
i think everybody is doing the waiting game on this one
unless your going to be the one to crack it open
12vstunna
Member - Posts: 16
Posted: January 18, 2009 at 1:12 PM / IP Logged
ok so i tried to copy and paste and sorry it didnt work but here you go ok
12v-14ga yellow/red under left side of dash in blue(tow package) connector
ign-18ga pink/white at ignition switch
starter-same wire as ignition 1
horn-no horn wire just use siren
lights(-)-18 ga white at light switch-use 3k ohm resistor also 640 ohm resistor on same wire turns on headlight
LF Door-18ga.violet (-) in harness coming up from floor under left side of dash
RF Door-18 ga.violet/white at same
LR Door-18 ga.violet/gray at same
RR Door-18 ga. violet / YELLOW at same
Interior Lights-18 ga.yellow/white behind light switch at green connector (+)
Lock Switch-MPX
Unlock Switch-MPX
and well thats what i used an no problems till this day
WHO NEEDS M.E.C.P ITS JUST A CERTIFICATE,OH AND I GOT THE SKILL TO PROVE THAT I DONT NEED ONE~XxX12vStunnaXxX~    X-Mobile Solutions
jsanchez71
Member - Posts: 28
Posted: January 20, 2009 at 12:18 AM / IP Logged
Thanks man, will try it over the weekend.
jsanchez71
Member - Posts: 28
Posted: February 09, 2009 at 8:10 PM / IP Logged
Which module do I need for remote start?
loneranger
Copper - Posts: 572
Posted: February 09, 2009 at 8:28 PM / IP Logged
DLPK or PKUCH2X(bypass only).
Ideal - cmon dude, add to topics in a useful manner, not stuff that is obvious.
Story - Phzzzt! Hey, what happened?! ... Isn't it obvious?
Moral - Never dismiss the obvious.
robertsc
Copper - Posts: 337
Posted: February 10, 2009 at 7:30 PM / IP Logged
so what the skinny on this vehicle
people run around saying its the new fob ignition that has no bypass available
had a customer tell me he has a regular chrysler key not a fob
has anybody done one
is it the same as a 2008 and use a pkuch2x
jsanchez71
Member - Posts: 28
Posted: February 11, 2009 at 1:10 PM / IP Logged
IMy supplier told me that those two modules won't work, he got in the phone with the people from directed and according to him, the module for this truck is not ready yet.
I'm not sure wich is the FOB key, but as I didn't have the module for the bypass, I installed a Viper 1002 on these trucks, the key that they have it is not as usual keys, when you insert it in the sw, you have to push it in, and if you disconect the harness from the sw, it won't release the key, kinds of get's locked in., all the wiring info from directech document's were accurate, couldn't install the 5900 that the customer wanted.
But according to the xpresskit page, that's the one, hope someone helps clarify this.
robertsc
Copper - Posts: 337
Posted: February 11, 2009 at 1:24 PM / IP Logged
a non fob key has a metal blade that you insert into the key cylinder
a fob key is all plastic
the end of the key is about the size or the end of your thumb
you insert and turn it
it uses the transponder to allow the vehicle start
the fob is a generic size and it is not cut like a conventional key
if that makes sense
http://superiorsportsinvestments.com/2008300c
jsanchez71
Member - Posts: 28
Posted: February 11, 2009 at 1:54 PM / IP Logged
The one's I did, had the metal blade cutted as normal key, with the only difference that right where the metal starts had a plastic square that fits into the key cylinder, that's what it looks different., but if this is a normal key, it should work with any od these modules  DLPK or PKUCH2X correct?
Page of 3
