how to test amp? blown?
leasureryan
Member - Posts: 9
Posted: January 27, 2009 at 6:24 PM / IP Logged
I just got this amp off ebay...MTX600XD ...perfect condition...lights come on, fueses are good....but it just doesn't seem to be amplifying....I don't know. How do I know if I should get my money back? I know I don't have it hooked up wrong....easy setup.
Platinum - Posts: 13,726
Posted: January 27, 2009 at 7:16 PM / IP Logged
Does the amp have any output at all?   Some MTX amplifiers can be muted by turning the gains all of the way down.  Have you checked to make sure the gains were not all the way down?  Have you checked the plus and minus configuration on the speaker terminals?  Some amps have the speaker terminals Plus Plus Minus Minus.
leasureryan
Member - Posts: 9
Posted: January 27, 2009 at 7:45 PM / IP Logged
yeah....everything is hooked up as it should be. And it is playing through the speaker.....but It's not getting very loud at all....I don't thiunk it's working. It's doing about as much as it would if I wired it directly to the head unit...like 35 watts or whatever.....I have such bad luck. How do I test this thing so I know if I can turn this thing sideways and shove it up dudes ass
Posted: January 27, 2009 at 7:53 PM / IP Logged
Do you have a dual voice coil woofer connected to the amp? If so disconnect one of the voice coils and see if it plays loud then.
leasureryan
Member - Posts: 9
Posted: January 27, 2009 at 8:05 PM / IP Logged
nope....single coil....and the speaker was fine when I last used it
Posted: January 27, 2009 at 8:18 PM / IP Logged
Well if you know you have good signal getting to the amp, it sounds to me as the amp is bad. If you have the tools necessary to take it apart, I can tell you what to look for just to make sure it is bad before you go and wrongfully turn it sideways.
leasureryan
Member - Posts: 9
Posted: January 27, 2009 at 8:42 PM / IP Logged
I just had it apart and everything looked great....I can see no visible burns/breaks etc. Everything looks brand new. I don't get it. Unless they droped it during shipping
Posted: January 27, 2009 at 8:47 PM / IP Logged
Did you remove any of the clamps that hold the transistors down to the heat sink? The power supply transistors could be cracked, but the amp will play with very low output, just as you are describing.
The power supply transistors are the ones nearest the transformer, the round ring with multi colored wires wrapped around it.
leasureryan
Member - Posts: 9
Posted: January 27, 2009 at 8:50 PM / IP Logged
no...I think that is beyond my abilities....I don't want to F things up....unless it's easy....got any pics of what you are talking about?
Posted: January 27, 2009 at 8:54 PM / IP Logged
Not of that particular amp. Do you have a digital camera so you can take a picture of the inside of the amp and send it to me?
Monday, April 6, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
