second stater wiring, 07 murano
kickercivic1
Member - Posts: 34
Posted: January 30, 2009 at 12:43 PM / IP Logged
I am installing remote start in 2007 Nissan murano. It has (+) second starter wire. How do i wire a relay up? by the way the alarm is Viper 5900.
Bnluis
Silver - Posts: 578
Posted: January 30, 2009 at 1:53 PM / IP Logged
at the relay pack of the viper 5900 there is a 4 pin harness, use the  small purple  wire to trigger a relay
purple pin 85
 pin 87 and 86 fuse 12v
pin 30 to second starter wire.
Luis
Sound Waves
Is up to the installer to test all wires with a DMM whenever possible.
t&t tech
Platinum - Posts: 2,622
Posted: January 30, 2009 at 4:51 PM / IP Logged
not to overshadow anyone but you can use a feed of the thick gauge starter wire to trigger the relay, wire it just as stated, but you can connect both feeds at the same point and solder makes the job easier and is less risky than splicing into those thin gauge wires on the ribbon of the relay pack. just a thought
joch1314
Copper - Posts: 301
Posted: January 30, 2009 at 5:23 PM / IP Logged
There's actually a seperate 4 pin harness that comes with that second starter output wire, and is different from the ribbon harness.  You just need a relay to "power it up enough" if you will.  But, yes i can see you using the original starter wire also!
...half of the truth can be worse than a lie. <----Roger Russell said that..
t&t tech
Posted: January 31, 2009 at 2:26 PM / IP Logged
oh my bad, i read it but my mind asumed it to be the ribbon, happens sometimes second stater wiring, 07 murano -- posted image.
kickercivic1
Member - Posts: 34
Posted: February 03, 2009 at 10:57 AM / IP Logged
So the second starter wire does not need to be cut?? Like first one???
loneranger
Copper - Posts: 572
Posted: February 03, 2009 at 10:59 AM / IP Logged
It can be, if you like. Key side would go to #87a.
Ideal - cmon dude, add to topics in a useful manner, not stuff that is obvious.
Story - Phzzzt! Hey, what happened?! ... Isn't it obvious?
Moral - Never dismiss the obvious.
t&t tech
Posted: February 03, 2009 at 3:14 PM / IP Logged
no it does not need to be, and there is no point in interrupting it, just cut the main starter wire, the second starter wire also referred to as the cold start wire only serves secondary purposes, and doesn't prevent the car from starting normally.
