fastening wires to sheet metal
asc1963
Member - Posts: 6
Posted: February 07, 2009 at 11:50 AM / IP Logged
Has anyone ever used this kind of wire fastener to fasten wires to sheet metal, like in the trunk or under the IP? I was wondering if they work.
asc
KPierson
Platinum - Posts: 3,527
Posted: February 07, 2009 at 4:08 PM / IP Logged
I've used the wire tie sticky things - little square bases that accept a wire tie.
I really like them, and they are reusable.  You just need to make sure you prep the surface correctly - just like with any sticky type solution.
Kevin Pierson
asc1963
Member - Posts: 6
Posted: February 07, 2009 at 5:13 PM / IP Logged
Yea, I've used them before. The reason I kinda thought these would work is I'm using them behind a panel that sits real close to the metal, there's hardly any clearance. it's either the wire straps or duct tape.
asc
asc1963
Member - Posts: 6
Posted: February 19, 2009 at 8:23 PM / IP Logged
update ... I ordered the wirestraps and they work great. super sticky adhesive and a real neat look. check them out here.
asc
ragsports
Copper - Posts: 192
Posted: February 21, 2009 at 11:15 AM / IP Logged
what model of the straps did you get?
asc1963
Member - Posts: 6
Posted: February 21, 2009 at 4:18 PM / IP Logged
The Professional version ... they claim they are used by the OEM's
asc
Wednesday, February 11, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
