wiring subs
j.reed
Copper - Posts: 716
Posted: February 11, 2009 at 11:03 PM / IP Logged
most is in the correct install, tuning and the most critical is the box itself. A prefab box is usually crap.
wiring subs - Page 2 -- posted image.
pitbulllover77
Member - Posts: 10
Posted: February 12, 2009 at 1:42 PM / IP Logged
done it like you said everything sounds great but if i turn my volume up the cd player shuts off when the bass hits and kicks back on!
Lyn
Platinum - Posts: 13,725
Posted: February 12, 2009 at 2:04 PM / IP Logged
Did you run your amp power wire to the battery?  Do you have the speaker wires of the radio and the amp both connected to one or more speakers?
Define kicks off and kicks back on.  Does the cd player turn off or does it just skip?
pitbulllover77
Member - Posts: 10
Posted: February 12, 2009 at 3:50 PM / IP Logged
the main power wire is run to the battery , i have two 5 1/4 speakers run to the radio itself and the subs bridged on the amp and the radio kicks off!
Lyn
Posted: February 12, 2009 at 4:02 PM / IP Logged
I am still trying to figure out what you mean by Kicks off.  Do the lights go out and the radio turn off, or does the music just quit for a second or two.
pitbulllover77
Member - Posts: 10
Posted: February 12, 2009 at 5:15 PM / IP Logged
music quits for a second or two but yes the power is completly kicking off too!
Lyn
moparfan1234
Copper - Posts: 59
Posted: February 19, 2009 at 11:41 PM / IP Logged
pitbulllover77 wrote:
looks easy enough will this give me the deep bass i`m looking for? and could you tell me if this is a good combination and wat if anything should i add next to really get the bass?
yea get a 1 ohm stable amp that the rms rating matchs the rms rating of both subs added together
87 ramcharger eclipse CD5000 2 15" memphis M3 kenwood 900rms mono amps
99 dodge cummins diesel eclipse CD4000 1 12" memphis Mclass 800rms audiobuhn amp
Tuesday, March 31, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
