Use keyless to activate shaved handles
DeathsJester12V
Silver - Posts: 352
Posted: March 23, 2003 at 3:40 PM / IP Logged
Otay....try this out....
Hook up lock and unlock, as you normally would for power locks.
Than use an auxillary channel of your alarm to trigger the door(s) to pop. You'll need to use a relay. follow the above set up. Just remember. If the alarm channel is going to put out a positive signal, instead of negative, you'll need to make 85 a ground.
