viper 5701 04 nissan murano rear defrost?
wretched4life
Posted: February 22, 2009 at 3:18 PM / IP Logged
I recently had a Viper 5701 installed in a 2004 Nissan Murano, and everything works great except for the rear window defroster that should turn on when the vehical is under 55 degrees (during remote start/run). I contacted Directed about the issue and they gave me updated information to give to the installer so the rear defrost would work. However, after the second time of having the vehicle worked on, it still does not work. Has anyone installed a 5701 Viper in a '04 Nissan Murano and been successful at hooking up the rear defrost so it turns on during remote start? Any help would be great.
SoundImage
Copper - Posts: 75
Posted: February 22, 2009 at 10:16 PM / IP Logged
it should be a GREEN/ red wire at the defrost relay in the driver kick panel brown plug this wire will activate the defrost for 8 min.
loneranger
Copper - Posts: 572
Posted: February 23, 2009 at 2:05 PM / IP Logged
How is the relay going to time itself?
Ideal - cmon dude, add to topics in a useful manner, not stuff that is obvious.
Story - Phzzzt! Hey, what happened?! ... Isn't it obvious?
Moral - Never dismiss the obvious.
Chris Luongo
Platinum - Posts: 3,746
Posted: February 23, 2009 at 4:13 PM / IP Logged
Does the car's radio come on during remote start?
There's a low-current, negative-trigger wire at the car's BCM that'll trigger the defroster.....but it only works if both of the car's accessory wires are powered during remote start.
If the radio isn't coming on during remote start, have the installer power up the car's blue/white second-accessory wire.
