2005 trailblazer ls
raf89
Posted: February 22, 2009 at 8:43 PM / IP Logged
Hello everyone!
I'm new here so bare with me =P.
Recently put a Clarion deck ( 7" screen), 2 12" Kenwood's and a 1200W Kenwood Amp... System runs decent with little dim when i really crank it., while driving.
I recently had the car parked and was waching some music videos on my screen with the bass pumping at mid range. I then started to see the car revin' ( I guess to charge up the battery) which pretty much wasn't enough.. So I decided to go around the block, I put the car in drive started to go and boom, my car shuts off. I turned it back on turned off the deck + the subs and drove around (everything was cool). Put it back in the same spot and left it on again with out anything on (subs + deck) seemed ok but it was still revin' every so often. My question is this, how bad is this for the truck? will a cap fix this? is this normal when haiving a system like this running on an OEM Altenator/Battery? What can I do so this doesnt happen again?
Sorry if my question is stupid or "nubish" but im not the smartest guy when it comes to this stuff. Thanks for any help =)
moparfan1234
Copper - Posts: 59
Posted: February 22, 2009 at 9:46 PM / IP Logged
cap wont help if your killing the battery sounds like you need a biger alternator to run your system that long at idl.
87 ramcharger eclipse CD5000 2 15" memphis M3 kenwood 900rms mono amps
99 dodge cummins diesel eclipse CD4000 1 12" memphis Mclass 800rms audiobuhn amp
